Filter SA Messages
Filter SA messages to determine which SA messages to accept from a peer and which SA messages to send to a peer. By default, no inbound or outbound filter exists.
  1. Enter either Global Configuration mode or VRF Router Configuration mode for a specific VRF context:
    enable
    configure terminal
    Optional: router vrf WORD<1-16>
  2. Create the inbound filter:
    ip msdp sa-filter in {A.B.C.D}
  3. Create the inbound filter route policy name:
    ip msdp sa—filter in {A.B.C.D} route-policy WORD<1-64>
  4. Create the outbound filter:
    ip msdp sa-filter out {A.B.C.D}
  5. Create the outbound filter route policy name:
    ip msdp sa—filter out {A.B.C.D} route-policy WORD<1-64>
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip msdp sa-filter in 21.0.0.2 route–policy helloworld
Variable definitions
The following table defines parameters for the ip msdp sa-filter command.
Variable
Value
{A.B.C.D}
Specifies the MSDP peer IP address.
Specifies the route policy name for an inbound or outbound filter.
